Hey all,
When I flatten this part and cut holes in it, the holes disappear when I uncheck the flatten feature. What am I doing wrong here? What's the difference between flatten and fold/unfold? Thanks
Hey all,
Flat Pattern is mainly used for visual purposes, creating flat pattern dxf's and drawings. Fold/Unfold is used for what you're trying to do, insert a feature in its flattened state, then folding it back up. It's a pretty simple fix on your end, just drag your cut feature in between Flatten-Bends 1 and Process-Bends1 and move your hole where it needs to be. Now you'll have that hole in flattened and unflatten states. Hopefully this helps! Thanks
Thanks for the help! Another question - if I Unfold, sketch holes and cut them, do I do a fold to get back to the folded shape? Or do I just roll back to before the unfold operation? I'm not sure what the difference is there. Just trying to figure out the best practices here with the sheet metal functions
Unfold seems to work just fine. Although when I go to re fold the part it gives me an error - This part contains features that cannot be unbent. SW seems to not want to fold my part back up after it's been unfolded. Any thoughts on this issue? Thanks
What type of feature are you trying to do? Is it on that cone part or something else? There definitely are some issues with Unfold/Fold as John pointed out that I've come across too, but not exactly sure what you're trying to do.
I only need to cut three holes in the cone shell shape and sketch on the surface of the cone.
Whenever I do an unfold I can't Fold the part back to its original shape again. This seemed to work ok when I was modeling a cylinder vs. a cone. It gives me the same error - This part contains features that cannot be unbent.
I see, so in this cone part since you already have the "Flatten-Bend1" and "Process-Bends1" in your tree, you won't need to add the Unfold or the Fold feature. Sorry, I put you in the wrong direction with that, as long as all your sketches and features remain in between "Flatten-Bends1" and "Process-Bends1" , you can just "roll to end" with your rollback bar.
I need to model a simple sheet metal part very similar to this except with a cylinder not a cone. Can someone direct me to 2-3 tutorials showing the basics of how to start with a blank part? I'm new to SW sheet metal and am getting stuck on how to create the first bend.
You just need to correctly order the feature in the tree. Check attached part.
Anything after flat pattern feature would vanish when part is folded back.
