Hello all.
I´m a new on this forum and 1 year user of SW2016.
I have, I think, quite easy problem, for you here and that is:
I would like a macro that will rename a part into a new name where new name consist a value of Properties in the CUSTOM tab and a value from Configuration Specific Tab where configuration is not allways default, so I need to read a name of active configuration and use it, but I don´t know how.
I was able to get so far but it dosn´t work and I don´t know whay:
Dim swConfig As SldWorks.Configuration
Dim swCompConfig As String
Dim configName As String
Dim partnumber As String
Dim imekosa As String
Set swModel = swApp.ActiveDoc
Set swConfig = swModel.GetActiveConfiguration
'Get configuration name
Set swCompConfig = swModel.ReferencedConfiguration
'Use this....To Get the value from the Properties in the CUSTOM tab
partnumber = swModel.GetCustomInfoValue(swCompConfig, "NumberNomenc")
imekosa = swModel.CustomInfo("FileNoProj")
'Or this....To Get the value from the Configuration Specific Tab
'partnumber = SWmoddoc.GetCustomInfoValue("Default", "Number")
PathName = swModel.GetPathName 'this gets the full path of the current open document (including filename)
FilePath = Left(PathName, InStrRev(PathName, "\")) 'uses to full pathname to get the folder path, to be added to the save as file name
If (swModel.GetType = swDocASSEMBLY) Then
swModel.SaveAs (FilePath + partnumber + ".sldasm")
ElseIf (swModel.GetType = swDocPART) Then
swModel.SaveAs (FilePath + partnumber + "_" + imekosa + ".sldprt")
I started from this macro wich I allready modified and it works, but only if active configuration is default.
Dim SWmoddoc As SldWorks.ModelDoc2
Set SWmoddoc = swApp.ActiveDoc
partnumber = SWmoddoc.GetCustomInfoValue("Default", "NumberNomenc")
imekosa = SWmoddoc.CustomInfo("FileNoProj")
PathName = SWmoddoc.GetPathName 'this gets the full path of the current open document (including filename)
If (SWmoddoc.GetType = swDocASSEMBLY) Then
SWmoddoc.SaveAs (FilePath + partnumber + ".sldasm")
ElseIf (SWmoddoc.GetType = swDocPART) Then
SWmoddoc.SaveAs (FilePath + partnumber + "_" + imekosa + ".sldprt")
Please help,
Jernej
Sorry, this line
should be
