After reinstalling SW (due to drive issues) I can no longer dynamically rotate a model using the mouse scroll button. Rolling the scroll wheel zooms in/out but no rotation.
Using the Shift or Ctrl buttons to manipulate the view no longer works either.
Is this a mouse setting problem or a SW setting problem. Using a Logitec M310 mouse that used to work fine.
Ended up replacing the Logitech wireless mouse with the same model and added it to my existing unifying usb receiver that was set up to run keyboard & mouse. That way it won't take up another usb port.
Still not sure if my old mouse has a bad button or a driver problem.....updating driver didn't help.. New mouse worked without problems.
At least it was just an $11.99 fix.
