I am trying to route two harnesses with identical connectors and wire connections. I grouped both harnesses into one harness in the Harness Manager but only one gets successfully routed.
The one that isn't routed still has a stub sticking out. However, all 8 pins were included so if anything I would have expected to see 8 stubs instead of just one.
If I look at FeatureManager, I can see that connector E1 (from the unrouted harnesses) did not get put into the same "Component" folder as the other connectors. Maybe that has something to do with it? Can anyone provide help or possible ways to identify the bug?
Hi Ming,
Are all of the connectors supposed to be connected with a single, continuous path? If not, we will want to create two separate harnesses in the 2D Schematic.
Best,
Loretta
