6 Replies Latest reply on Feb 2, 2017 7:32 AM by Fatih Özcan
    How to disable sketch picture scale tool in Vba?
    Fatih Özcan
      Only think I am able to find in Sketch picture properties is swSketchPictureTransparencyStyle
      2016 SOLIDWORKS API Help - swSketchPictureTransparencyStyle_e Enumeration
      What is necessary code to disable scale tool for a sketch picture? It shows lines when sketch picture is added and because of logic of macros, I don't want to disable them manually
        • Re: How to disable sketch picture scale tool in Vba?
          Raghvendra Bhargava
          Try this:
          Option Explicit
          Dim swFeat As SldWorks.Feature
          Dim swSketchPicture As SldWorks.SketchPicture
          Dim boolstatus As Boolean
          Dim width As Double
          Dim height As Double
          Dim angle As Double
              Set swModel = swApp.ActiveDoc
              swModel.SketchManager.InsertSketch True
              Set swSketchPicture = swModel.SketchManager.InsertSketchPicture("YourImage Path")
              'swModel.SketchManager.InsertSketch True
              swApp.RunCommand swCommands_Ok_Command, "" 'It will close Command
              Fatih Özcan
              No luck
              This is what I am using right now
              Dim skPicture As Object
              Set skPicture.swModel.SketchMamnager.InesrtSketchPicture("image path")
              skPicture.SetSize 0.012, 0.006, 1
              skPicture.SetOrigin 0.348, 0.014
              swModel.ClearSelection
              'and another picture to be added with same code as upper paragraph
                  Raghvendra Bhargava
                  HiFaith,
                  There is no direct API to check or Uncheck scale tool.
                  But I got the another work around to delete scale tool.
                  Try This:
                  Dim swapp As SldWorks.SldWorks
                  Dim skPicture As SketchPicture
                  Dim swmodel As ModelDoc2
                  Set swapp = Application.SldWorks
                  Set swmodel = swapp.ActiveDoc
                  boolstatus = swmodel.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0) '>>Select Your Plane
                  swmodel.SketchManager.InsertSketch True
                  Set skPicture = swmodel.SketchManager.InsertSketchPicture("Your Image Path")
                  swmodel.ViewZoomtofit2
                  swmodel.ClearSelection
                  Dim skSegment As SketchSegment
                  Dim swSketch As Sketch
                  Set swSketch = swmodel.SketchManager.ActiveSketch
                  Dim ArrSeg As Variant
                  ArrSeg = swSketch.GetSketchSegments
                  Set skSegment = ArrSeg(0)
                  skSegment.Select4 False, Nothing
                  Dim myBlockDefinition As SketchBlockDefinition
                  Set myBlockDefinition = swmodel.SketchManager.MakeSketchBlockFromSelected(Nothing)
                  swmodel.EditDelete
                  swmodel.ForceRebuild3 True
