DPDan Pihlaja26/01/2017
Ok, so here is the scenario:
I am using SW 2015 SP5.
In a part, after creating the base feature, I create a single thru hole using the hole wizard.
Then I create a sketch with points in it for the location of the rest of the holes (NOT a 3D sketch).
Then I use the sketch with points to create a sketch driven pattern to pattern the hole that I just created with the hole wizard.
Now, I create a drawing of the part.
When I use the "Hole Callout" tool to dimension the hole, the quantity does not show up.  It doesn't matter if I select the original hole or any of the patterned holes.
Can anyone else verify this?
Is this the proper intended function?
