How do I make a far side countersink connect properly to the through hole?
Question asked by Harry Burger on Jan 26, 2017
Latest reply on Feb 14, 2017 by Jody Stiles
Using the advanced hole feature, I select a far side countersink, specify a depth for the countersink, and make a matching through hole above it in the stack as "up to next element."  I always wind up with the through hole stopping short, so there's a revolved triangle shape of material rather than the through hole going until it all breaks through.  If I try to make the through hole Blind, I can't extend it without it throwing an error, and making it shorter only makes things worse.  Reducing the depth of the countersink gives me the opposite problem, where there is a flat circle at the bottom of the countersink instead of going down until cone meets cylinder.
