I have been having lots of trouble in the following scenario:
I have an assembly containing subassemblies. If I select a subassembly in the graphics area of the top assembly and hit the Delete key, SW deletes either the selected feature of the subassembly or the component of the subassembly, not the subassembly itself.
Is there a cure for this bad behavior?
Hello Walter,
Several releases ago there was an "enhancement" that allowed you to delete components from a sub-assembly from a upper level assembly (with no warning). It was roundly despised, so was modified in SW2015 (see here) to provide a dialog box to clarify what you want to delete. Are you not getting that?
