API - Reset to original Configuration After Cycling
Question asked by Kevin Collins on Jan 24, 2017
Latest reply on Jan 24, 2017 by Kevin Collins
Hi All,
I am working on a macro to cycle through all configurations of a given document and force rebuild each one.  I found the code (below) for the basics on the SW API help site.  It works great except for one minor issue.
I need the macro to reset the active configuration to the original configuration (whichever was active when the macro was started) after it has rebuilt the last one.
Currently it will cycle through all configurations and, once the last one has been rebuilt it remains the active configuration.
Please help!
Here is the code I am working with:
    Dim vConfNameArr As Variant
    Dim sConfigName As String
    Dim start As Single
    Dim i As Long
    Dim bShowConfig As Boolean
    Dim bRebuild As Boolean
    Dim bRet As Boolean
    Set swModel = swApp.ActiveDoc
    Debug.Print "File = " + swModel.GetPathName
    vConfNameArr = swModel.GetConfigurationNames
    For i = 0 To UBound(vConfNameArr)
        sConfigName = vConfNameArr(i)
        bShowConfig = swModel.ShowConfiguration2(sConfigName)
        start = Timer
        bRebuild = swModel.ForceRebuild3(False)
        Debug.Print "  Configuration = " & sConfigName
        Debug.Print "    ShowConfig  = " & bShowConfig
        Debug.Print "    Rebuild     = " & bRebuild
        Debug.Print "    Time        = " & Timer - start & " seconds"
    Next i
Thanks in advance!!
