hello everyone
I couldn't find size 16" and 18" pipes and fittings in solidworks design library and I was adviced I should add them to the design table for each fitting so they would be included in the design library for future use, and that's what I had done, except for it keeps repeating this silly error (please find attached screenshot)
After adding new size configuration, did you re-add the component to the Routing Library by using the Routing Components Wizard? It should pass its criteria easily because it should already be fully defined as required.
Also, simple question here, do you have any of the RPoint or CPoints, or other required routing definitions asked for by the RCWiz, suppressed in this new configuration? They need to be present for all configs, and individually assigned per config. If nothing else, running it through the RCWiz will help illustrate what is missing, if there are any needed items missing.
Routing sure is picky. Sometimes I give up and start over, though I'm not necessarily suggesting that for you.
