Have tried all versions for eDrawings for my computer with Win 10 32-bit. Please let me know what I can do?
With Draftsight you may be able to get an older version to work on a 32 bit machine (probably a 2014 version) but you would also have to run it in compatibility mode to Windows 7 or older. Not sure if you can even load it successfully though.
An older version of eDrawings may also possibly work the same way but you would not be able to read files newer than the version of eDrawings you end up using. Again, not sure if you will even be able to install.
I just upgraded to 64 bit system for the same reason (except I was running Vista).
It's not that expensive these days and the performance is far superior and you are going to run into this problem more and more as almost nothing is being made to run on 32 bit anymore.
Per eDrawings System Requirements, there is only 64 bit version for Win 10. So better upgrade your OS/system to 64 bit.
For what purpose you need the eDrawings?
Also, 32-bit systems are capped at 4 GB of RAM, which I don't recommend for anything but viewing the simplest components or drawings. To me, that alone is the clincher to decide on 64-bit hereafter.
So, which one worked?
