Working with some of our older parts I noticed in the drawings, and parts that, in the file properties/BOM, that there are references to weight, material size, and over all weight. When I make a new part, and I go to set the file properties, and those properties that I mentioned are not listed in the "Value/Text Expression" field. How would I get these fields to be present with every new part?
Do you use Custom Property Tab Builder?
If not, see the attached - Modify with
