I have a screw, a nut and a washer that I want to put together in a size 1 hole. How do I make them all fit together size-wise? Also how do I rotate the different components?
You can add mates to all these parts
Concentric, coincident between holes and faces
In addition to what John posted, you can lock the concentric mates to prevent rotation if you want.
Lisa Midjo wrote: Also how do I rotate the different components?
In the Assembly File, RMB on a part and select Move with Triad...
Rick Becker wrote: Lisa Midjo wrote: Also how do I rotate the different components?In the Assembly File, RMB on a part and select Move with Triad...
Rick Becker wrote:
...or just click on the bolt head and drag. It will spin it if it's not constrained.
