I want to delete the selected piece and keep the floating piece. Once I hit delete it deletes everything. The floating piece will be put into assembly, I needed the larger piece for measure.
Few Options:
1 Do not model what you don't need
2 Model them with merge result unchecked and then you can use delete bodies
3 Use cut extrude feature to remove the area/material you don't need.
