I am trying to run a static analysis on electric bikes frame but I am not sure if all the loads and fixture that I applied are enough to get the correct result .
I do have the results but still not sure if this is correct.
I would appreciate an expert advise .
I look forward to hearing from you.
Thank you
So far these results are gibberish.
Your connections aren't setup completely. Parts aren't fully constrained, so they're flying off into the ether (note the high values in the displacement plot). You shouldn't need "soft springs" enabled to solve this study. If you have SW 2016 you can use the new "find unconstrained bodies" command to help hunt down these issues.
Some of your parts are sheet metal, so they're getting a shell mesh. I doubt this is your intention.
