Hallo,
I have a question about Hole table.
I wrote a macro that modify the cell in the description colum where the cell value in empty (for me it'snt a hole wizard),
so I add "It's not a Hole Wizard"
But if I want add a text (ex. "See section") in the exist text cell is it possible without touch the variables?
This row of code does't works:
Dim testo As String
testo = swTableAnnotation.Text(intRow, intCol)
swTableAnnotation.Text(intRow, intCol) = testo & " See section "
This is my actual macro:
Dim swHoleTable As SldWorks.HoleTable
Dim swHoleTableAnnotation As SldWorks.HoleTableAnnotation
Dim swTableAnnotation As SldWorks.TableAnnotation
Dim swAnnotation As SldWorks.Annotation
Dim boolstatus As Boolean
Set swModel = swApp.ActiveDoc
boolstatus = swModel.Extension.SelectByID2("Tabella di foratura1", "HOLETABLE", 0, 0, 0, False, 0, Nothing, 0)
Set swHoleTable = swSelMgr.GetSelectedObject6(1, -1)
Set swHoleTableAnnotation = swHoleTable.GetTableAnnotations(0)
Set swTableAnnotation = swHoleTableAnnotation
Set swAnnotation = swTableAnnotation.GetAnnotation
If swHoleTable Is Nothing Then
MsgBox ("Hole table is nothing")
End
start:
Dim intCol As Integer
For intCol = 0 To swTableAnnotation.ColumnCount - 1
For intRow = 1 To swTableAnnotation.RowCount - 1
Debug.Print swTableAnnotation.Text(intRow, intCol)
If swTableAnnotation.Text(0, intCol) = "DESCRIZIONE" Then
Dim testo As String
If testo = "" Then
Dim value As Boolean
value = swTableAnnotation.DeleteRow(intRow)
GoTo start
swTableAnnotation.Text(intRow, intCol) = "This is not a Hole Wizard"
Debug.Print swTableAnnotation.Text(intRow, 0)
Next intRow
Next intCol
swHoleTable.EnableUpdate = True ' Update hole table and model view
Thanks a lot
It's the Text property help page, it's say:
