Hi, I recently had Solidworks 2017 re-installed, and everything was working fine until I saved a drawing template into the default templates folder. Somehow this caused my part and assembly templates to disappear? I saved over the original drawing template in order to remove the default sheet style, so that I would be prompted to select a sheet style in the future. I also noticed that the part and assembly templates were deleted from the tutorial folder as well. Does anyone have any idea what is going on?
Can you double check the folder from tools>options ... if there is any file in there
