8 Replies Latest reply on Feb 1, 2017 1:55 PM by Ryan Gerry
    GetObject returning nothing in 2017
    Ryan Gerry
      After installing SW2017 'GetObject(, "Sldworks.Application")' started to return no value in an Excel to SW macro (VBA). I have tried 'swApp = GetObject(, "Sldworks.Application")' and 'Set swApp = Application.SldWorks' with the same results. This macro has been running successfully in a number of versions prior. Has anyone run into this? Has anyone resolved this?
      Public Sub SW3dPoints1()
          Dim Part As SldWorks.ModelDoc2
          Dim Feat As SldWorks.Feature
          Dim i As Integer
          Dim count As Integer
          Dim mySketchPoint As SldWorks.SketchPoint
          Dim pxf As String
          Dim myNote As SldWorks.Note
          Dim Annotation As Object
          Dim pX, pY, pZ As Variant
          Dim pName As Variant
          Dim nmArr() As Variant
          Dim pat As String
          Dim conversion As Double
          Dim selmgr As SldWorks.SelectionMgr
          Dim ranges As Range, sName As Range
          Dim MessageBox As Integer
          Dim numSets As Integer
          Dim curSet As Integer
          Dim Fctr As Integer
          Dim didNm As Boolean
          Dim SkNmArr As Variant
          Dim sufX As String
          Dim ifExCt As Variant
      MessageBox = MsgBox("Prerequisites: SolidWorks is running with a new Part Document open.  Sketches are closed.  A workbook containing X, Y, and Z coordinates to be plotted is open.  If desired, these points have a leftmost column containing their point name, which can be attatched as an annotation. " & vbCrLf & vbCrLf & "Press Cancel to stop and meet Prerequisites.", vbOKCancel)
      If MessageBox = 2 Then
      Exit Sub
          On Error Resume Next
         ' Set swApp = CreateObject("SldWorks.Application")
         ' Set swApp = GetObject(, "Sldworks.Application")
          If swApp Is Nothing Then [this line is returns true]
          MsgBox "Macro could not find Solidworks Document.  Open Solidworks and rerun Macro." [Message is displayed]
          Exit Sub [Macro Ended]
      ...Code continues... [Macro is long and requires swAPP to be set]
      Thanks!
      -Ryan
