CustomPropertyManager Does not seem to work on Mirror Parts
Question asked by Brian Smith on Jan 18, 2017
Latest reply on Jan 23, 2017 by Amen Allah Jlili
   For whatever reason, whenever I run the below macro (as a macro feature running on rebuild) on a mirrored part it changes nothing. It should be deleting and replacing the material property with some text.
Example of a thicknessmaterial would be "0.250-ASTM A36" so Material would read "ASTM A36".
(The custom property thicknessmaterial actually equals the SW Material. We do this to control the color by using the SW material and color is determined by grade and thickness. A future macro feature I want to make is to control the color automatically by cross referencing the sheetmetal thickness and SW Material, but this does explain this problem...)
Function swmRebuild(varApp As Variant, varDoc As Variant, varFeat As Variant) As Variant
    Dim swCustPropMgr As SldWorks.CustomPropertyManager
    Dim App As SldWorks.SldWorks
    Dim Doc As SldWorks.ModelDoc2
    Dim feat As SldWorks.Feature
    Dim FeatData As SldWorks.MacroFeatureData
    Dim Rebuild As Boolean
    Dim val As String
    Dim valout As String
    Dim bool As Boolean
    Dim Position As Long
    Dim Length As Long
    Set App = varApp
    Set Doc = varDoc
    Set feat = varFeat
    Set swCustPropMgr = Doc.Extension.CustomPropertyManager("")
    bool = swCustPropMgr.Get4("ThicknessMaterial", False, val, valout)
    Position = InStr(1, valout, "-")
    Length = Len(valout)
    MsgBox swCustPropMgr.Count
    bool = swCustPropMgr.Delete2("Material")
    If (0 < Position) Then
         Doc.AddCustomInfo2 "Material", swCustomInfoText, Right(valout, Length - Position)
    Else
         Doc.AddCustomInfo2 "Material", swCustomInfoText, valout
    Set evHdlr = New EventHandler
    Rebuild = True
End Function
I found a way around this by deleting the custom property "Material" out of my part template. But I see this is a dumb work around, and I see other people having problem with mirrored parts custom properties with macros and I am not confident enough to know that I am doing it right.
