Hallow everyone
I want to simulate my PC water cooling system in SolidWorks symulation.
At the moment I have problem with recrieting pump in system.
At the moment I made closed loop with internal fun to generate flow.
My problem is:
I do not rally know how to simulate pump at the moment.
Pump in the system was tested on this forum:
http://www.xtremesystems.org/forums/showthread.php?170217-Some-Laing-D5-Testing-13-1-24V-is-the-same
Official product info for EK D5 pump:
- Maximum pressure head: 3.9m
- Maximum flow: 1500L/h
Is this correct way to test pump for SolidWorks simulation.
If so How can I convert it to usable data?
Regards Arek
Setup form post:
I understand that to get proper parameters (pressure difference) to simulate pump in loop, I would need to add other inlet of the manometer before the pump?
Is that correct?
