When I click on OPEN FILE or type OPEn in the Command window the explorer box does not appear. Is there a setting to turn this on?
Are you talking about DraftSight? If Yes then both things works fine for me. Try restarting your machine OR reinstall DraftSight.
Yes, it is Draftsight. Tried rebooting and re-install same thing happens.
Could be possible that dialog boxes have been set to off.
Type FILEDIA or DISPLAYDIALOGS (case not sensitive) at the command window. And then type Y (case not sensitive). Now check again.
I've added a video to show the above command.
That was it!
Thank you
