I am sure this question must be answered somewhere, somehow I could not find the answer.
I have a part with multiple configurations, each having configuration specific property named "Description" . Apart from this I have Custom property, which is not configuration specific named Description.
The difference between the value of configuration specific and generic is that in custom Specific, I have values that is describing the size of the part. e.g "EXHAUST TUBE, 6in", where as generic Description property has value "EXHAUST TUBE". I am trying to link the note in the drawing with the generic value of the part, All I am getting is the option to pick the description property of the Configurations (See below image).
Could someone suggest me any method to link the note to the Generic property?
The Property on the "Configuration specific Tab" will take priority over the "custom Tab"
So if the same Property exists on both Tabs, only one will show.
unless you need to show the 6" somewhere else, I would delete the "Description" on the Config. Tab.
