3 Replies Latest reply on Jan 18, 2017 6:39 AM by William Cruz
    HELP on macro for Convert sketchpoint coordinate to assembly
    roberto gennari
      Hallo,
      I need to convert the coordiante of the sketch point to assembly coordiante.
      I tried this macro to convert but the result in wrong, the correct result are the coordiante in the lower of frame of SolidWorks (see the image)
      The part in the assembly is traslate in X axis of 100 mm about, so the assembly origin and the part origin insn't the same.
      The macro return the point coordinate reference to the part(model) not the conversion of the assembly coordinate.
      have you any idea how to fix it?
      Thanks a lot
      Roberto
      ' Preconditions:
      '       (1) Part, assembly or drawing is open.
      '       (2) If a part or assembly, then a sketch is being edited.
      '       (3) If a part or assembly, then an entity is selected in
      '           the sketch.
      '       (4) If a drawing, then an entity is selected.
      ' Postconditions: None
      ' NOTES:
      '       (1) If the sketch is a 3D sketch, then the selected sketch
      '           point is automatically in model coordinates.
      '       (2) If the sketch is a 3D sketch, then its transform is the
      '           unit transform.
      Option Explicit
      Public Function GetModelCoordinates(swApp As SldWorks.SldWorks, swSketch As SldWorks.Sketch, vPtArr As Variant) As Variant
          Dim swMathPt                    As SldWorks.MathPoint
          Dim swMathUtil                  As SldWorks.MathUtility
          Dim swMathTrans                 As SldWorks.MathTransform
          Set swMathUtil = swApp.GetMathUtility
          Set swMathPt = swMathUtil.CreatePoint(vPtArr)
          ' Is a unit transform if 3D sketch; for example, selected sketch
          ' point is automatically in model space
          Set swMathTrans = swSketch.ModelToSketchTransform
          Set swMathTrans = swMathTrans.Inverse
          Set swMathPt = swMathPt.MultiplyTransform(swMathTrans)
          GetModelCoordinates = swMathPt.ArrayData
      End Function
          Dim swApp                       As SldWorks.SldWorks
          Dim swModel                     As SldWorks.ModelDoc2
          Dim swSelMgr                    As SldWorks.SelectionMgr
          Dim swSketch                    As SldWorks.Sketch
          Dim vSketchSelPt                As Variant
          Dim vModelSelPt                 As Variant
          Dim i                           As Long
          Set swModel = swApp.ActiveDoc
          Set swSketch = swModel.GetActiveSketch2
          vSketchSelPt = swSelMgr.GetSelectionPointInSketchSpace(1)
          vModelSelPt = GetModelCoordinates(swApp, swSketch, vSketchSelPt)
          Debug.Print "File = " & swModel.GetPathName
          Debug.Print "  Is3D sketch          = " & swSketch.Is3D
          Debug.Print "  SelPt (sketch space) = (" & vSketchSelPt(0) * 1000# & ", " & vSketchSelPt(1) * 1000# & ", " & vSketchSelPt(2) * 1000# & ") mm"
          Debug.Print "  SelPt (model  space) = (" & vModelSelPt(0) * 1000# & ", " & vModelSelPt(1) * 1000# & ", " & vModelSelPt(2) * 1000# & ") mm"
      Result in the immediate window
        Is3D sketch          = Falso
        SelPt (sketch space) = (138, 283.85, 0) mm
        SelPt (model  space) = (138, 283.85, 6.81797779247439) mm
      I need:
      X-19.5 Y283.85 Z 6.8179
