It is full of triangles, a solid model or normal surfaces would be great. STL attached. Thank you all. Rod. 425-686-2436 xrodinary@yahoo.com
Hi Rod,
This would require several hours, and would need additional details about how the frets should be handled. Because the resolution of the scan is low, and the scan is rough it would be hard to determine the actual width of the frets, particularly if you were using some type of standard thickness component to insert into a groove.
I suggest you place this in the job postings section of the forum.
