Orientation to origin API
Question asked by Kai Jordan on Jan 15, 2017
Latest reply on Jan 18, 2017 by William Cruz
Hi Guys
The example shows the simple selection of a part or an assembly.
I do not want to select an item.
I want to select many element.
I find in the API help is not the right solution maybe somebody help me.
Here is the example:
This example shows how to align an assembly component to the assembly origin and planes.
' Preconditions: Assembly document is open and
'                an assembly component is selected.
' Postconditions: Selected assembly component is
'                aligned to the assembly origin and planes.
Option Explicit
    Dim swApp                   As SldWorks.SldWorks
    Dim swMathUtil              As SldWorks.MathUtility
    Dim swModel                 As SldWorks.ModelDoc2
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swComp                  As SldWorks.Component2
    Dim swXform                 As SldWorks.MathTransform
    Dim i                       As Long
    Dim bRet                    As Boolean
    Set swMathUtil = swApp.GetMathUtility
    Set swModel = swApp.ActiveDoc
    Set swComp = swSelMgr.GetSelectedObjectsComponent3(1, 0)
    Set swXform = swMathUtil.CreateTransform(Nothing)    ' create unit transform
    swComp.Transform2 = swXform
    ' Rebuild to see updated transform
    bRet = swModel.EditRebuild3: Debug.Assert bRet
Greetings Kai Jordan
