What is Solidworks visualize boost use for? Where can I get help on using this?
Hi Mukesh ,
forward to what Brian mentioned , boost has many advantages over traditional network renders as we also have the abiliity to utilize it in the actual project environment, this is called Powerboost and uses the same principals.
so with Visualize Boost you create clusters of computers so that you can use their resources to more quickly render out images and animations and using Powerboost you can utilize those same resources to more quickly set up your projects without any slow down from waiting for your image to res up.
definitely check out Brian's links above as Boost is a really great asset for SOLIDWORKS Visualize
Hi Mukesh,
Welcome to the Visualize Community. You can learn more about the benefits of Visualize Boost through this link below:
Visualize Boost | Visualization Packages | SOLIDWORKS
Here is a link to learn about how to install it and set it up:
SOLIDWORKS Visualize 2017 SP0.0 Documentation (UPDATED)
Feel free to ask any questions you have in this Visualize Forum. We have a ton of active, passionate users who are happy to lend a hand.
Brian HILLNER
Product Manage | SOLIDWORKS Visualize
