I have a spiral, but I want a straight line that turns into a spiral at the end like a corkscrew. How do I combine a line and spiral?
Start a 3d sketch. Use convert entities to convert the spiral to a sketch entity. Add an arc to one end of it, and then a straight line on the other end of the arc. Add a tangent relation at each endpoint of the arc, add relations so that the straight line is going down the center of the spiral, and you're done.
Edit: I got to thinking, and you'll need two arcs, not one. See below.
