Issue connecting to Solidworks Electrical after migration to new SQL server.
Question asked by Andrew Skemp on Jan 12, 2017
Latest reply on Jan 26, 2017 by Evan Stanek
Hello, we are currently running Solidworks Electrical 2015. Our SQL database was recently migrated over to a new server and we have run into some issues. None of our projects appear in Solidworks Electrical. Below is the error we receive from the query execution error log:
1/11/2017 9:52:20 AM FONCTION:TrADLRecordsetADO::openSQL PARAM:SELECT col_id ,col_code ,col_position ,col_value ,col_rgb ,col_creationdate ,col_modificationdate ,col_datatype  FROM tew_color ; MESSAGE:Invalid object name 'tew_color'. (Number : -2147217865)
1/11/2017 9:52:20 AM FONCTION:TrADLRecordsetADO::openSQL PARAM:SELECT cap_no,cap_value FROM tew_config_app; MESSAGE:Invalid object name 'tew_config_app'. (Number : -2147217865)
1/11/2017 9:52:29 AM FONCTION:TrADLRecordsetADO::openSQL PARAM:SELECT col_id ,col_code ,col_position ,col_value ,col_rgb ,col_creationdate ,col_modificationdate ,col_datatype  FROM tew_color ; MESSAGE:Invalid object name 'tew_color'. (Number : -2147217865)
1/11/2017 9:52:29 AM FONCTION:TrADLRecordsetADO::openSQL PARAM:SELECT cap_no,cap_value FROM tew_config_app; MESSAGE:Invalid object name 'tew_config_app'. (Number : -2147217865)
1/11/2017 9:52:29 AM FONCTION:TrADLRecordsetADO::openSQL PARAM:SELECT prf_id ,prf_name ,prf_level ,prf_creationdate ,prf_modificationdate ,prf_datatype  FROM tew_profile ; MESSAGE:Invalid object name 'tew_profile'. (Number : -2147217865)
1/11/2017 9:52:29 AM FONCTION:TrADLRecordsetADO::openSQL PARAM:SELECT gro_id ,gro_prf_id ,gro_name ,gro_desc ,gro_creationdate ,gro_modificationdate ,gro_datatype  FROM tew_group ; MESSAGE:Invalid object name 'tew_group'. (Number : -2147217865)
1/11/2017 9:52:29 AM FONCTION:TrADLRecordsetADO::openSQL PARAM:SELECT usr_id ,usr_gro_id ,usr_username ,usr_pwd ,usr_firstname ,usr_lastname ,usr_initial ,usr_signblock ,usr_creationdate ,usr_modificationdate ,usr_datatype  FROM tew_user ; MESSAGE:Invalid object name 'tew_user'. (Number : -2147217865)
1/11/2017 9:52:29 AM FONCTION:TrADLRecordsetADO::openSQL PARAM:SELECT pro_id,pro_type,pro_indefaultpath,pro_name,pro_path,pro_pdmvault,pro_pdmuser,pro_directory,pro_state,pro_revisonno,pro_customername,pro_custaddress1,pro_custaddress2,pro_custaddress3,pro_drawingofficename,pro_doaddress1,pro_doaddress2,pro_doaddress3,pro_contractnb,pro_version,pro_nod_clauid,pro_creationdate ,pro_modificationdate ,pro_datatype ,pro_lib_name  ,use_objectid ,use_objectno ,use_data0 ,use_data1 ,use_data2 ,use_data3 ,use_data4 ,use_data5 ,use_data6 ,use_data7 ,use_data8 ,use_data9 ,use_data10 ,use_data11 ,use_data12 ,use_data13 ,use_data14 ,use_data15 ,use_data16 ,use_data17 ,use_data18 ,use_data19  FROM tew_project  LEFT JOIN tew_userdata ON tew_project.pro_id = tew_userdata.use_objectid ; MESSAGE:Invalid object name 'tew_project'. (Number : -2147217865)
The sql instance and hostname are still the same with the new server and all databases located in the instance backed up and restored correctly. I've confirmed that the tew login has permissions to the tables listed and I am unsure what else to check.
