Hi all,
I am wondering if there is functionality for the following:
I have selected hundreds of faces and have deleted the faces. However, what I would like to do is to ALSO make a surface copy (zero offset) of those faces before I delete them. In other words, I would like SW to allow me to roll back my deleted face feature, but know and select the faces that were selected inside the deleted face feature, let me make a copy surface of them, then roll forward the delete face. (I'm giggling a little as I type this as I know I am probably asking for a lot).
If anything, I would want to select a bunch of faces, create a zero offset of the faces, have SW keep the faces selected, then perform the delete face command.
I was trying to think of a possible macro, but can't think of any calls that would allow me to do that.
This may sound strange, but trust me, I need to be able to do this....
Any help would be appreciated.
Mike
Mike,
there is the face selection filter that you can take advantage of for rapidly selecting the faces from the model and in cases like this I turn view to wireframe and then use lasso select.
but also - your idea of a persistent selection set sounds like a great enhancement.
mark
