FlatPattern MergeFace Change Macro
Question asked by Brian Smith on Jan 11, 2017
Latest reply on Jan 12, 2017 by Brian Smith
My company has changed how we do flat pattern drawings such that it requires the "mergeface" feature of the flat pattern feature to be turned off.
This is not a problem going forward for new parts and components, but if we want to reuse old components or parts, I want to make a macro so it makes the require changes to be updated to the new standard (merge face change being one of a few).
Where I am getting hung up on is that the API doesn't offer a "SetMergeFace" method for the flat pattern interface.
Being new to VBA and the solidworks API I assume I can change the parts flat pattern public property MergeFace, but it does not seem to make any changes.
2015 SOLIDWORKS API Help - IFlatPatternFeatureData Interface Members
Simple code:
Dim swApp As Object
Dim Part As Object
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Part.FeatureByName("Flat-Pattern1").GetDefinition.MergeFace = False
This effectively produces no change to the flat pattern feature
Breaking it out doesn't do anything:
Set swFeat = Part.FeatureByName("Flat-Pattern1")
Set swFlatPattern = swFeat.GetDefinition
swFlatPattern.MergeFace = False
Not knowing better, I assumed I am missing something with the access selection. I don't really understand the purpose of the .IAccessSelection2 method of the flat pattern interface. I assume it unlocks editing to the flat pattern feature? But when I have the code below I get "run time error '61836': Unable to read write-only property."
Dim Component As Component2
boolstatus = swFlatPattern.IAccessSelections(Part, Component)
Is there a way to edit the mergeface option of the flat pattern feature in a macro?
