Hello again,
This question is associated with a previous question I had which can be found at Want to add a SEARCH COLUMN for ....? .
I installed the "WorkflowStateAddin - 1(WLM Services LLC)" recently and found it to be very helpful but lacking in one area that is very important to me. That is, there is not a menu selection to add a Menu Command for running the addin.
Here is an image of the PDF Task. Note, it DOES have a Menu Command choice available:
The "Workflow State Task Addin" does not offer this choice:
Can anyone provide some guidance on how I can add the "Menu Command" selection to the "Workflow State Task Addin".
Thanks!!
If you watch the video on how to set it up on YouTube, you'll see that it is a scheduled Task not run from a menu.
