11 Replies Latest reply on Jan 11, 2017 11:59 AM by Deepak Gupta
    Macro Help
    David Johnson
      I came across this macro  on here a while back and am having a little trouble getting it to work, any help would be greatly appreciated
        • Re: Macro Help
          Deepak Gupta
          I've not tried your macro but try if the attached works. It is the same macro you've uploaded and I've updated the referenced only.
            • Re: Macro Help
              David Johnson
              Hi Deepak,
              I'm still getting the same error, at line 226 sSketchNameArr is highlighted as a compile error: ByRef argument type mismatch
                • Re: Macro Help
                  Deepak Gupta
                  Check now, have rearranged some lines.
                    • Re: Macro Help
                      David Johnson
                      i'm now getting: line 220 - Type mismatch
                      Thanks for your help so far
                        • Re: Macro Help
                          Amen Allah Jlili
                          can you post the macro code? I don't have SW on this machine.
                            • Re: Macro Help
                              David Johnson
                              Option Explicit
                              Const swTnProfileFeature As String = "ProfileFeature"
                              Const nTolerance As Double = 0.00000001
                              Sub FindAllUnderConstrainedSketches(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, sSketchNameArr() As String)
                              Dim swSketch As SldWorks.Sketch
                              Dim swFeat As SldWorks.Feature
                              Dim bRet As Boolean
                              Set swPart = swModel
                              Set swFeat = swPart.FirstFeature
                              Do While Not swFeat Is Nothing
                              If swTnProfileFeature = swFeat.GetTypeName Then
                              Set swSketch = swFeat.GetSpecificFeature2
                              If swUnderConstrained = swSketch.GetConstrainedStatus Then
                              sSketchNameArr(UBound(sSketchNameArr)) = swFeat.Name
                              ReDim Preserve sSketchNameArr(UBound(sSketchNameArr) + 1)
                              Set swFeat = swFeat.GetNextFeature
                              Loop
                              ' Remove last empty sketch name
                              ReDim Preserve sSketchNameArr(UBound(sSketchNameArr) - 1)
                              Function GetAllSketchLines( _
                              swApp As SldWorks.SldWorks, _
                              swModel As SldWorks.ModelDoc2, _
                              swSketch As SldWorks.Sketch) As Variant
                              Dim vSketchSegArr As Variant
                              Dim vSketchSeg As Variant
                              Dim swSketchSeg As SldWorks.SketchSegment
                              Dim swSketchCurrLine As SldWorks.SketchLine
                              Dim swSketchLineArr() As SldWorks.SketchLine
                              ReDim swSketchLineArr(0)
                              vSketchSegArr = swSketch.GetSketchSegments
                              If Not IsEmpty(vSketchSegArr) Then
                              For Each vSketchSeg In vSketchSegArr
                              Set swSketchSeg = vSketchSeg
                              If swSketchLINE = swSketchSeg.GetType Then
                              Set swSketchCurrLine = swSketchSeg
                              Set swSketchLineArr(UBound(swSketchLineArr)) = swSketchCurrLine
                              ReDim Preserve swSketchLineArr(UBound(swSketchLineArr) + 1)
                              Next
                              If 0 = UBound(swSketchLineArr) Then
                              ' No straight lines in this sketch
                              GetAllSketchLines = Empty
                              Exit Function
                              ' Remove last empty sketch line
                              ReDim Preserve swSketchLineArr(UBound(swSketchLineArr) - 1)
                              GetAllSketchLines = swSketchLineArr
                              End Function
                              Function GetSketchPoint( _
                              swSketch As SldWorks.Sketch, _
                              swSketchPt As SldWorks.SketchPoint) As Boolean
                              Dim vSketchPtArr As Variant
                              vSketchPtArr = swSketch.GetSketchPoints
                              If Not IsEmpty(vSketchPtArr) Then
                              ' Use first point
                              Set swSketchPt = vSketchPtArr(0)
                              GetSketchPoint = True
                              Exit Function
                              GetSketchPoint = False
                              End Function
                              Function FindVerticalOrigin( _
                              swSketchSegVert As SldWorks.SketchSegment, _
                              swSketchPtVert As SldWorks.SketchPoint) As Boolean
                              Dim vSketchLineArr As Variant
                              Dim vSketchLine As Variant
                              Dim swStartPt As SldWorks.SketchPoint
                              Dim swEndPt As SldWorks.SketchPoint
                              ' Try to get first vertical line
                              vSketchLineArr = GetAllSketchLines(swApp, swModel, swSketch)
                              If Not IsEmpty(vSketchLineArr) Then
                              For Each vSketchLine In vSketchLineArr
                              Set swSketchCurrLine = vSketchLine
                              Set swStartPt = swSketchCurrLine.GetStartPoint2
                              Set swEndPt = swSketchCurrLine.GetEndPoint2
                              If Abs(swStartPt.X - swEndPt.X) < nTolerance Then
                              Set swSketchSegVert = swSketchCurrLine
                              FindVerticalOrigin = True
                              Exit Function
                              Next
                              ' Try to get the first point
                              FindVerticalOrigin = GetSketchPoint(swApp, swModel, swSketch, swSketchPtVert)
                              End Function
                              Function FindHorizontalOrigin( _
                              swSketchSegHoriz As SldWorks.SketchSegment, _
                              swSketchPtHoriz As SldWorks.SketchPoint) As Boolean
                              ' Try to get first horizontal line
                              If Abs(swStartPt.Y - swEndPt.Y) < nTolerance Then
                              Set swSketchSegHoriz = swSketchCurrLine
                              FindHorizontalOrigin = True
                              Exit Function
                              Next
                              FindHorizontalOrigin = GetSketchPoint(swApp, swModel, swSketch, swSketchPtHoriz)
                              End Function
                              Function AutoDimensionSketch( _
                              swSketch As SldWorks.Sketch) As Long
                              Dim swSketchSegHoriz As SldWorks.SketchSegment
                              Dim swSketchPtHoriz As SldWorks.SketchPoint
                              Dim swSketchSegVert As SldWorks.SketchSegment
                              Dim swSketchPtVert As SldWorks.SketchPoint
                              Dim bRet As Boolean
                              If False = FindHorizontalOrigin(swApp, swModel, swSketch, swSketchSegHoriz, swSketchPtHoriz) Then
                              AutoDimensionSketch = swAutodimStatusDatumLineNotHorizontal
                              Exit Function
                              If False = FindVerticalOrigin(swApp, swModel, swSketch, swSketchSegVert, swSketchPtVert) Then
                              AutoDimensionSketch = swAutodimStatusDatumLineNotVertical
                              Exit Function
                              Set swFeat = swSketch
                              bRet = swFeat.Select2(False, 0)
                              Debug.Assert bRet
                              ' Editing sketch clears selections
                              swModel.EditSketch
                              ' Reselect sketch segments for autodimensioning
                              If Not swSketchSegVert Is Nothing Then
                              ' Vertical line is for horizontal datum
                              bRet = swSketchSegVert.Select4(True, Nothing)
                              ElseIf Not swSketchPtHoriz Is Nothing Then
                              bRet = swSketchPtHoriz.Select4(True, Nothing)
                              ElseIf Not swSketchPtVert Is Nothing Then
                              ' Use any sketch point for horizontal datum
                              bRet = swSketchPtVert.Select4(True, Nothing)
                              Debug.Assert bRet
                              If Not swSketchSegHoriz Is Nothing Then
                              ' Horizontal line is for vertical datum
                              bRet = swSketchSegHoriz.Select4(True, Nothing)
                              ' Use any sketch point for vertical datum
                              Debug.Assert bRet
                              ' No straight lines, probably contains circles,
                              ' so use sketch points for datums
                              If IsEmpty(GetAllSketchLines(swApp, swModel, swSketch)) Then
                              bRet = swSketchPtHoriz.Select4(False, Nothing)
                              bRet = swSketchPtVert.Select4(False, Nothing)
                              Debug.Assert bRet
                              AutoDimensionSketch = swSketch.AutoDimension2(swAutodimEntitiesAll, _
                              swAutodimSchemeBaseline, _
                              swAutodimHorizontalPlacementBelow, _
                              swAutodimVerticalPlacementLeft)
                              ' Redraw so dimensions are displayed immediately
                              swModel.GraphicsRedraw2
                              ' Exit sketch edit
                              ' Leave rebuild to later
                              swModel.InsertSketch2 False
                              End Function
                              Dim sSketchNameArr() As String
                              Dim sSketchName As Variant
                              Dim nRetVal As Long
                              Dim i As Long
                              Dim bRet As Boolean
                              Set swModel = swApp.ActiveDoc
                              Debug.Print "File = " & swModel.GetPathName
                              ReDim sSketchNameArr(0)
                              FindAllUnderConstrainedSketches swApp, swModel, sSketchNameArr
                              For Each sSketchName In sSketchNameArr
                              Set swFeat = swPart.FeatureByName(sSketchName)
                              nRetVal = AutoDimensionSketch(swApp, swModel, swSketch)
                              Debug.Print " " & sSketchName & " = " & nRetVal
                              Next
                              ' Rebuild after modifying sketches
                              bRet = swModel.EditRebuild3
                              Debug.Assert bRet
                            • Re: Macro Help
                              Deepak Gupta
                              Are you running it on a part file?
                      • Re: Macro Help
                        Amen Allah Jlili
                        it looks to me that this macro is a modified version of this
