I'm trying for a few hours to convert an enclosed surface into a solid body but it does not make the command. I manage to make the knit of the surfaces and the check box with the "create solid" appears. I select that check box and the command aparently do what it's supposed to do, however, a solid body does not appear on the feature tree and it remains, hollow.
If anyone know how to solve the problem, please report your experience.
Thanks in advance,
Ricardo Peixoto
remove surface sweep 10 and fill it with a surface loft, then you can make it a solid from there. surface sweep 9 and 10 over lap
