hi,
I had a macro that was running fine until we have just changed to 2016 SP5, when I debug the macro I get the error Object library feature not supported.
Sub Main()
Dim swModel As ModelDoc2
Dim swDraw As DrawingDoc
Dim FilePath As String
Dim PDFpath As String
Dim PathSize As String
Dim dwgname As String
Dim dwgFilePath As String
Set swModel = swApp.ActiveDoc
'Check if a file is open
If swModel Is Nothing Then
MsgBox ("Please open a Tooling Assembly Drawing and Re Run the macro.")
Exit Sub
'Check if a drawing is open
If Not swModel.GetType = swDocDRAWING Then
Exit Sub
'Get PDF name
FilePath = swModel.GetTitle
PathSize = Strings.Len(FilePath)
dwgname = Strings.Left(FilePath, PathSize - 16)
'Check if PDF is already open
If IsFileOpen("P:\Tooling Assemblies\Tooling Assembly Drawings\TA-1001.pdf") Then
' if file open, user message stating the file in use.
MsgBox dwgname & ".pdf" & " is already opened" & vbCr & " File cannot be saved" & "Close Tool Assembly Data Base and Re Run Macro"
Exit Sub
Else
PDFpath = "P:\Tooling Assemblies\Tooling Assembly Drawings\" & dwgname & ".pdf"
longstatus = swModel.SaveAs3(PDFpath, 0, 0)
'Save Drawing
dwgFilePath = swModel.GetPathName
longstatus = swModel.SaveAs3(dwgFilePath, 0, 0)
'Save Drawing as PDF and close document
swApp.CloseDoc swModel.GetTitle()
Function IsFileOpen(filename As String)
Dim filenum As Integer, errnum As Integer
On Error Resume Next
filenum = FreeFile()
' Attempt to open the file and lock it.
Open filename For Input Lock Read As #filenum
Close filenum
errnum = Err
On Error GoTo 0
' Check to see which error occurred.
Select Case errnum
Case 0
IsFileOpen = False
Case 70
IsFileOpen = True
' Another error occurred.
Case Else
Error errnum
End Select
End Function
Regards
Mat
Though fixing references should fix the issue else copy paste these codes into a new macro and try that.
