Refresh Configuration Properties
Question asked by Ben Manders on Jan 9, 2017
Latest reply on Jan 11, 2017 by Ben Manders
I am working on doing some work updating properties and am unable to determine a way to refresh the UI so that the changes I make display right away.  For the below example, I change the configuration name to "NumberABC" and the configuration description to "DescriptionABC".  The display for the number updates immediately however the description doesn't show until I cycle back and forth to the design tree tab.  I've tried using EnableGraphicsUpdate, GraphicsRedraw2, and ForceRebuildAll without noticing a change in behavior.  I also have a similar problem when updating the custom properties of the configuration.
Public Sub mainTest()
    Dim sValOut As String
    Dim sResolvedValOut As String
    Set swModel = swApp.ActiveDoc
    Set swConfig = swModel.GetActiveConfiguration
    Set swModelView = swModel.ActiveView
    'swModelView.EnableGraphicsUpdate = False
    'Configuration Properties
    swConfig.Name = "NumberABC" 'Number
    swConfig.Description = "DescriptionABC"
    'swModelView.EnableGraphicsUpdate = True
    'swModel.GraphicsRedraw2
    'swModel.Rebuild (swForceRebuildAll)
