No one else has this question
Check solution offered by Walter Klemp here https://forum.solidworks.com/message/541331#comment-541331
Hi Jonathan,
This is obviously NOT normal behaviour and whilst it may seem a little trivial issue, there should still be a remedy for it?
Dave.
Well you might want to try the reset registry method: Resetting the SOLIDWORKS registry
If that doesn't work out then please call your VAR/SOLIDWORKS reseller (from whom you've bought the SOLIDWORKS software) and ask their team to investigate.
Do share the outcome as it might help others with similar issues.
Glen,
Following the thread you posted, Dennis Bacon linked another thread
https://forum.solidworks.com/message/465067
- there was a solution found for SW2015 - Maybe this will work here also.
Hi Jonathan,
Are you saying that the modify box always highlights the top line and not the bottom (dimension) line?
Dave.
