Hi Everyone,
Please see attached.
I am having a little trouble with a simple assembly I am trying to render. The assembly consists of some grilles and two pieces of glass. At the angle I have chosen the grills end up with a "stepped appearance" which is certainly accurate in real life but for my purposes I need to remove this step.
Any thoughts or ideas on how I can do this.
Any help would be greatly appreciated.
Jeff SChreiber
Jeff,.. a quick/temp workaround.. change the two under faces into area lights (under counter lighting)...
..or,..change/rotate the angle of your background (or use another or custom base plane)
