The slide jaw part doesn't have a face in front or back. Is there a way to use existing lines and points to create faces in front and back?
Unless your intention is to learn surfacing, I'd find it easier to delete the Surface-Extrude1, keep its sketch, and use its sketch to create a Boss-Extrude instead.
If you're better off with surfaces instead of solids, then you still do not need an additional feature to enclose the ends. Select [_] Cap end within the Surface-Extrude feature:
If you want both ends capped, select Direction 2, Blind, Distance zero, and cap its end also.
you can use "convert entities" to copy lines - By the way, missing parts from your assembly in the zip folder
