I have a PC with a conventional hard drive and a solid state drive, C; is the conventional with 200 gig the SS drive E; has 1 Tb, my conventional has 12 gig left free and the machine is suffering, correction I am suffering.
How can I or is it advisable to move my data to the solid state drive while leaving the OS on the conventional drive?
Can I install Solid Works and other program's to the solid state?
Hi Paul,
You should be able to move all data to the SSD, all file references will be broken as the drive letter has changed.
You can manually re-reference as you open files. If all referenced files are in the same folder you should only have to tell it once for every assembly you open and it will load the rest from there.
If you want Solidworks to do the job, go to system options>File Locations>referenced documents and add the upper level of the directory you moved your data to. That way it'll search that directory for files where the references are broken (turn on 'search file locations for external references'. This will only work if your naming conventions are tight and you don't have duplicate filenames in different projects, as it will pick up the first file it finds with the same name.
For a mind bending read on file search routines CHECK THIS OUT 2016 SOLIDWORKS Help - Search Routine for Referenced Documents
Installing your software onto the SSD should not be a problem either. Back up your settings with copy settings wizard. Ensure you clean the reg etc when you uninstall. Once you've uninstalled everything you intend to move to the SSD run a defrag or 2 on the conventional drive.
