WSWill Smith22/11/2008
So, I have had many issues trying to knit surfaces that
should knit perfectly.
Example 1:
Copy faces of a solid (created in SW 2009)
hide copies
delete originals
attempt to knit, failure to knit faces, with any option set.
(and when this happens, replace face crashes SW)
Example 2:
Knit feature yields a solid, but if I go back in the tree and change something elsewhere in the model, the knit fails.
Example 3:
Imported geometry, forget it.
Example 4:
Knit feature yields a solid, do a verified rebuild and knit fails to rebuild.
I know what you are thinking....Perhaps I have invalid geometry? Well to me, if it worked once, twice, three times...It should work again! Ya....Do an entity check! Well, SW crashes when I use check entity...
In examples 1, 2, and 4, all faces will knit to adjacent faces, but will not knit surface body to surface body. The only solution I have found is to manually select each face, which can literally take hours, and it might not even work.
I spend about 2 hours per day dealing with this issue.
I am seriously pissed. My VAR is so far incapable of helping me solve this issue.
Yet another reason to switch to think3!
Example 1:
hide copies
delete originals
Example 2:
Example 3:
Example 4:
