Can I do a vault search for just a project folder?
Since you use project name as part of the document name so you have issue with filtering the project name for searching
The project and document names have the same name but their properties are different.
So to filter the project name for searching, you can use advance search and select the property
In the image in my previous post, "preliminary" is a document's property and it I opted "Does not contain", so when I search, all document names is skipped
Dave,
You can add multiple lines to the search with the AND/OR criteria. So as Christian Chu suggests you could search for "Document" Starts Wtih xxxx then add AND "Document" does not contain yyyy. This should help reduce the search return.
Daen
You can use Daen Hendrickson suggestion to eliminate all SW files (see below image) or you, as an admin, can access to VaultAdmin to add document properties such as lfiecycle so you can use it to filter the search
I just tried it and it seems to work. If you do a find/search and use the project name in the "document" field.
