Hi All,
Background: I'm using the SolidWorks Document Manager API to extract Parasolid parts from SolidWorks files.
I can successfully extract the Solid Bodies as Parasolid Transmit and Partition files (using GetImportedBody and GetPartitionStream on the ISwDMConfiguration3 object respectively), but for most files I don't get the friendly names that appear inside SolidWorks in the Project Tree (in a group called Solid Bodies).
Does anyone know if there is a way to get this from the SLDPRT file?
The occasional Parasolid Part seems to have a name attribute set (SDL/TYSA_NAME) but most do not.
Thanks for any advice,
Dan
Renamed title "Software" -> "SolidWorks"
If I'm understanding you question correctly then you should just be able to use the Name prop. from Body2. See link below.
2016 SOLIDWORKS API Help - Name Property (IBody2)
