Bug in SW when using external sketch for pattern?
Question asked by Mikael Martinsson on Jan 4, 2017
Latest reply on Jan 4, 2017 by Mikael Martinsson
Hi.
I'm using SW2017SP1 and have a problem when using an external sketch for a pattern.
- Working in an assembly
- I have a reference part with a simple sketch containing only sketch points.
- I add a simple cylindrical part (se picture) and mate its origin to one of the sketch points
- If I now do an assembly pattern of the cylindrical part, using the sketch points from the reference part, it works fine:
- If i instead wants to edit the cylinder part and do a body pattern inside this part, it also works
- However, the rebuild icon now appears on the part and it never goes away, as if I had circular reference.
- The only relation between Reference part and cylinder is a mate between origin and one of the sketch points.
- If i remove this mate and instead fixes the cylinder part, to avoid the possibility of a circular reference, it is still the same:
Is this a bug in SW2017SP1  or am I missing something obvious here?
