I have to design a hydraulic manifold
Can anyone share Common cavity library? Or is there a site to download common cavities profile to add in library.
Looking forward to replies.
Regards,
Regards,
Hello your library you can build yourself up you get all parts
On the tracepart site:
Http://www.tracepartsonline.net/(S(yljecwabykvtltq5pxcfrzkp))/content.aspx?lang=DE&class=LEGRIS
If you work with parker model you can access any standard you Need.
These parts can also be used as a basis for the Rooting Tool.
The import I would run over the SolidWorks taskplaner next to
If you have any questions just ask.
Kai Jordan
I don't have any on hand. We keep them locked up as reference only models as we did not do any design work on them and they have no revision control. I would suggest getting ahold of your vendor and seeing what they have available for solid models. We have used Bosch/Rexroth in the past and have requested 3D models of the manifolds for assembly/layout purposes. Most vendors have models of their manifolds but I don't know about libraries.
