Every time I start with new assembly file I have to activate this pane tool then only I can have a parts origin plane visible. Is there any way to make this activation default?
Go to File>Open and in the Open dialog select Template for file type, then open your assembly template. Make the changes how you want the plane visibility to be and save. Now when you start a new assembly, the planes should be how you want.
