Let me API skills to a higher level in new year.
Question asked by Yong Ning on Dec 31, 2016
Hope in the new year, let my solidowrks API skills to a higher level.
Must be familiar key Syntax
1  GetFirstDisplayDimension + GetDimension + GetAnnotation + GetPosition Syntax
function code
Function NoDelDimension(SwDraw As DrawingDoc, SwView As View, NoDelDim)
        tmp = SwDraw.Extension.SelectByID2(ViewName, "DRAWINGVIEW", 0#, 0#, 0, True, 0, Nothing, 0)
        Annotations = SwDraw.InsertModelAnnotations3(0, 1736728, False, True, True, True)        ''
        For ii = 0 To UBound(Annotations)           ''
           Set SwAnn = Annotations(ii)
           Set SwDispDim = SwAnn.GetSpecificAnnotation
           Set SwDim = SwDispDim.GetDimension
        Next ii
             If UCase(SwAnn.GetName) Like "*DN*" Or UCase(SwAnn.GetName) Like "*THK*" Then
                SwAnn.Select True
        Next ii
End Function
Function BreakOut(SwDraw As DrawingDoc, SwView As View)
    Dim Ww, Hh
        SwDraw.ActivateView SwView.Name
        SwDraw.ForceRebuild3 True
        Var = SwView.GetOutline
        For ii = 0 To 3
          Var(ii) = Var(ii) / SwView.ScaleDecimal
        Next ii
        Ww = Var(2) - Var(0)
        Hh = Var(3) - Var(1)
        With SwDraw
             .SketchRectangle -Ww / 2, -Hh / 2, 0, Ww / 2, Hh / 2, 0, True
             .CreateBreakOutSection Depth / 1000
        End With
End Function
2  InsertFamilyTableNew + GetOLEObjects(Vv) +
Function RngInsertDesign(SwModel As ModelDoc2, Xls As Excel.Application, _
       ConfRng As Range, ConfHeadRng, ConfTabRng, MassRng As Range, retuDimRng As Range, _
       CutPlateCustInfoRng As Range, CutDimRng As Range)
   SwModel.InsertFamilyTableNew
   Dim SwOleObj As SwOLEObject, vOle, Vv As Long
       vOle = SwModel.Extension.GetOLEObjects(Vv)
       Set SwOleObj = vOle(UBound(vOle))
       Set Wk = SwOleObj.SetActive(True)
       ConfHeadRng.Copy
       With Wk.Sheets(1).Range("B2")
           .PasteSpecial xlPasteFormats
           .PasteSpecial xlPasteValues
       End With
       SwOleObj.SetActive False
       Set SwDesgTab = SwModel.GetDesignTable
       SwDesgTab.Attach
       SwModel.CloseFamilyTable
    For ii = 1 To ConfRng.Rows.Count
       With SwModel
           Str = "@@" & ConfRng(ii, 1) & "@" & .GetTitle & """"
           .AddCustomInfo3 ConfRng(ii, 1), "质量", 30, """SW-Mass" & Str
           '.AddCustomInfo3 ConfRng(ii, 1), "下料质量", 30, "/"
           .CustomInfo2(ConfRng(ii, 1), "质量") = """SW-Mass" & Str
           .AddCustomInfo3 ConfRng(ii, 1), "材料", 30, """SW-Material" & Str
           If UCase(.GetTitle) Like "*SLDASM*" Then
                .CustomInfo2(ConfRng(ii, 1), "材料") = "组合件"
                Set SwAssy = SwModel
                CompArr = SwAssy.GetComponents(True)
                SumVolMass SwModel, CompArr, ConfRng(ii, 1)
           Else
                .CustomInfo2(ConfRng(ii, 1), "材料") = """SW-Material" & Str
           .ForceRebuild3 False
       End With
End Function
3 InsertBomTable2 + ReferencedConfiguration + SwBomFeat.SetConfigurations
Function A3InsertBom(SwView As View, xx, yy, BOMPath)
  Dim AnchorType, BomType
    AnchorType = SwConst.swBOMConfigurationAnchor_BottomRight
    BomType = SwConst.swBomType_e.swBomType_TopLevelOnly
    Configuration = ""
    Set swBomAnn = SwView.InsertBomTable2(False, xx / 1000, yy / 1000, AnchorType, BomType, Configuration, BOMPath)
  Dim SwBomFeat As BomFeature, Names, Visible
    Set SwBomFeat = swBomAnn.BomFeature
    Names = SwBomFeat.GetConfigurations(False, Visible)
    For jj = 0 To UBound(Names)
       If Names(jj) = SwView.ReferencedConfiguration Then
          Visible(jj) = True
          Exit For
    Next jj
    boolstatus = SwBomFeat.SetConfigurations(False, Visible, Names)
End Function
