2 Replies Latest reply on Aug 6, 2017 10:01 AM by Yong Ning
    SwDim.ReferencePoints+MathPoint
    Yong Ning
      Follow code, result is Error.
      Help me .
      How to use MathPoint and ReferencePoints?
      Private Sub ll()
         Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
             Set SwApp = Application.SldWorks
             Set SwModel = SwApp.ActiveDoc
         Dim SwDraw As DrawingDoc
             Set SwDraw = SwModel
         Dim SwSelMgr As SelectionMgr
             Set SwSelMgr = SwModel.SelectionManager
         Dim SwDispDim As DisplayDimension, SwDim As Dimension
             Set SwDispDim = SwSelMgr.GetSelectedObject5(1)
             Set SwDim = SwDispDim.GetDimension
             ss = SwDim.ReferencePoints
         Dim SwPt As MathPoint, SwPt1 As MathPoint, SwPt2 As MathPoint
             Set SwPt = ss(0)
             Set SwPt1 = ss(1)
             Set SwPt2 = ss(2)
         Dim Xx, Yy, Xx1, Yy1, Xx2, Yy2
             Xx = SwPt.ArrayData(0)
             Yy = SwPt.ArrayData(1)
             Xx1 = SwPt1.ArrayData(0)
             Yy1 = SwPt1.ArrayData(1)
             Xx2 = SwPt2.ArrayData(0)
             Yy2 = SwPt2.ArrayData(1)
             Debug.Print Xx * 1000, Yy * 1000
             Debug.Print Xx1 * 1000, Yy1 * 1000
             Debug.Print Xx2 * 1000, Yy2 * 1000
             SwModel.CreateLine2 Xx1, Yy1, 0, Xx2, Yy2, 0
             SwModel.CreateLine2 Xx, Yy, 0, Xx2, Yy2, 0
             SwModel.CreateLine2 Xx1, Yy1, 0, Xx, Yy, 0
        • Re: SwDim.ReferencePoints+MathPoint
          Yong Ning
          Need skill
          ModelToViewTransform
          SketchPoint Coordinates to Model Coodinates | SOLIDWORKS Forums  https://forum.solidworks.com/message/691470
          Dimension Edge in Drawing Example (VB)
          This examples shows how to dimension an edge in a drawing view.
          ' Problem:
          '       This example shows how to automatically add a
          '       dimension to a straight edge in all drawing views
          '       in which it appears. The edge geometry is transformed
          '       to the space of each drawing view and, depending on
          '       whether it is horizontal or vertical, an appropriate
          '       style of dimension is added.
          '       This example could form the basis for an application
          '       to automatically dimension a model when it is added to
          '       a drawing.
          ' Preconditions:
          '       (1) Part or assembly is open.
          '       (2) If an assembly, it is fully resolved.
          '       (3) A straight edge is selected in the SolidWorks graphics area.
          ' Postconditions:
          '       (1) New drawing is created with three views.
          '       (2) If possible, the previously selected edge
          '          is dimensioned in all drawing views.
          ' NOTE:  The dimension is not created if
          '        the edge cannot be converted in a drawing view.
          Option Explicit
          Public Const LINE_TYPE              As Integer = 3001
          Public Const CIRCLE_TYPE            As Integer = 3002
          Public Const ELLIPSE_TYPE           As Integer = 3003
          Public Const INTERSECTION_TYPE      As Integer = 3004
          Public Const BCURVE_TYPE            As Integer = 3005
          Public Const SPCURVE_TYPE           As Integer = 3006
          Public Const CONSTPARAM_TYPE        As Integer = 3008
          Public Const TRIMMED_TYPE           As Integer = 3009
          ' Define two types
          Type DoubleRec
              dValue As Double
          End Type
          Type Long2Rec
              iLower As Long
              iUpper As Long
          End Type
          ' Extract two integer values out of a single double value,
          ' by assigning a DoubleRec to the double value and
          ' copying the value over an Long2Rec and
          ' extracting the integer values.
          Function ExtractFields _
          ( _
              ByVal dValue As Double, _
              iLower As Long, _
              iUpper As Long _
              Dim dr                          As DoubleRec
              Dim i2r                         As Long2Rec
              ' Set the double value
              dr.dValue = dValue
              ' Copy the values
              LSet i2r = dr
              ' Extract the values
              iLower = i2r.iLower
              iUpper = i2r.iUpper
          End Function
              Const sPathToTemplate           As String = "c:\Program Files\SolidWorks\data\templates\drawing.drtdot"
              Const nTolerance                As Double = 0.00000001
              Const nXoffset                  As Double = 0.01
              Const nYoffset                  As Double = 0.01
              Dim swApp                       As SldWorks.SldWorks
              Dim swModel                     As SldWorks.ModelDoc2
              Dim swSelMgr                    As SldWorks.SelectionMgr
              Dim swEdge                      As SldWorks.Edge
              Dim swEnt                       As SldWorks.entity
              Dim swCurve                     As SldWorks.Curve
              Dim vCurveParam                 As Variant
              Dim nDummy                      As Long
              Dim nIdentity                   As Long
              Dim nTag                        As Long
              Dim nSense                      As Long
              Dim swMathUtil                  As SldWorks.MathUtility
              Dim nPtData(2)                  As Double
              Dim vPtData                     As Variant
              Dim swModelStartPt              As SldWorks.MathPoint
              Dim swModelEndPt                As SldWorks.MathPoint
              Dim swViewStartPt               As SldWorks.MathPoint
              Dim swViewEndPt                 As SldWorks.MathPoint
              Dim swDraw                      As SldWorks.DrawingDoc
              Dim swDrawModel                 As SldWorks.ModelDoc2
              Dim swView                      As SldWorks.view
              Dim swViewXform                 As SldWorks.MathTransform
              Dim vOutline                    As Variant
              Dim swDispDim                   As SldWorks.DisplayDimension
              Dim nXpos                       As Double
              Dim nYpos                       As Double
              Dim bRet                        As Boolean
              Set swModel = swApp.ActiveDoc
              Set swEdge = swSelMgr.GetSelectedObject5(1)
              Set swCurve = swEdge.GetCurve
              Set swEnt = swEdge
              vCurveParam = swEdge.GetCurveParams2
              ExtractFields vCurveParam(8), nDummy, nIdentity
              ExtractFields vCurveParam(9), nDummy, nTag
              ExtractFields vCurveParam(10), nDummy, nSense
              Debug.Print "Start      = (" & vCurveParam(0) * 1000# & ", " & vCurveParam(1) * 1000# & ", " & vCurveParam(2) * 1000# & ") mm "
              Debug.Print "End        = (" & vCurveParam(3) * 1000# & ", " & vCurveParam(4) * 1000# & ", " & vCurveParam(5) * 1000# & ") mm "
              Debug.Print "Uparam     = [" & vCurveParam(6) & ", " & vCurveParam(7) & "]"
              Debug.Print "Identity   = " & nIdentity
              Debug.Print "Tag        = " & nTag
              Debug.Print "Sense      = " & nSense
              ' Derived quantity
              Debug.Print "Length     = " & swCurve.GetLength2(vCurveParam(6), vCurveParam(7)) * 1000# & " mm "
              Debug.Print ""
              ' Only makes sense for straight edges
              If LINE_TYPE <> nIdentity Then Exit Sub
              Set swMathUtil = swApp.GetMathUtility
              nPtData(0) = vCurveParam(0)
              nPtData(1) = vCurveParam(1)
              nPtData(2) = vCurveParam(2)
              vPtData = nPtData
              Set swModelStartPt = swMathUtil.CreatePoint(vPtData)
              nPtData(0) = vCurveParam(3)
              nPtData(1) = vCurveParam(4)
              nPtData(2) = vCurveParam(5)
              vPtData = nPtData
              Set swModelEndPt = swMathUtil.CreatePoint(vPtData)
              ' Start creating drawing of the model
              Set swDraw = swApp.NewDocument("C:\Program Files\SolidWorks\data\templates\drawing.drwdot", swDwgPaperAsize, 0, 0)
              Set swDrawModel = swDraw
              bRet = swDraw.Create3rdAngleViews2(swModel.GetPathName)
              Debug.Assert bRet
              Set swView = swDraw.GetFirstView
              Set swView = swView.GetNextView
              Do While Not swView Is Nothing
                  ' Select regardless
                  bRet = swView.SelectEntity(swEnt, False)
                  Debug.Assert bRet
                  vOutline = swView.GetOutline
                  Set swViewXform = swView.ModelToViewTransform
                  Set swViewStartPt = swModelStartPt.MultiplyTransform(swViewXform)
                  Set swViewEndPt = swModelEndPt.MultiplyTransform(swViewXform)
                  Debug.Print "View       = " & swView.Name
                  Debug.Print "Start      = (" & swViewStartPt.ArrayData(0) * 1000# & ", " & swViewStartPt.ArrayData(1) * 1000# & ", " & swViewStartPt.ArrayData(2) * 1000# & ") mm "
                  Debug.Print "End        = (" & swViewEndPt.ArrayData(0) * 1000# & ", " & swViewEndPt.ArrayData(1) * 1000# & ", " & swViewEndPt.ArrayData(2) * 1000# & ") mm "
                  Debug.Print ""
                  If Abs(swViewStartPt.ArrayData(0) - swViewEndPt.ArrayData(0)) < nTolerance Then
                      ' Must be vertical
                      ' Place dimension midway up edge and to the right of view
                      nXpos = vOutline(0) - nXoffset
                      nYpos = Abs((swViewStartPt.ArrayData(1) + swViewEndPt.ArrayData(1)) / 2#)
                      ' NULL if cannot convert edge in this view
                      Set swDispDim = swDrawModel.AddVerticalDimension2(nXpos, nYpos, 0#)
                  ElseIf Abs(swViewStartPt.ArrayData(1) - swViewEndPt.ArrayData(1)) < nTolerance Then
                      ' Must be horizontal
                      ' Place dimension midway across edge and above view
                      nXpos = Abs((swViewStartPt.ArrayData(0) + swViewEndPt.ArrayData(0)) / 2#)
                      nYpos = vOutline(3) + nYoffset
                      Set swDispDim = swDrawModel.AddHorizontalDimension2(nXpos, nYpos, 0#)
                  Else
                      ' Neither horizontal or vertical
                      ' Place dimension near middle of edge
                      nXpos = Abs((swViewStartPt.ArrayData(0) + swViewEndPt.ArrayData(0)) / 2#) + nXoffset
                      nYpos = Abs((swViewStartPt.ArrayData(1) + swViewEndPt.ArrayData(1)) / 2#) + nYoffset
                      ' Depends on the orientation of the entity in the drawing view,
                      ' thus, could be NULL
                      ' Create the dimension even if the entity is not
                      ' visible in the drawing view
                      Set swDispDim = swDrawModel.AddDimension2(nXpos, nYpos, 0#)
              Loop
              Yong Ning
              Function DelSkPt(SwModel As ModelDoc2, SwSk As Sketch)
                   Dim Ss
                   Dim SkPt As SketchPoint
                       If IsEmpty(SwSk.GetSketchPoints) Then
                           Exit Function
                       For Each Ss In SwSk.GetSketchPoints
                           Set SkPt = Ss
                           SkPt.Select True
                       Next
                       SwModel.EditDelete
              End Function
              Function RetuDimArr(SwView As View, SwDim As Dimension, oScale)
                  Dim vPos, Pt(2, 1), MathPt As MathPoint
                  Dim Ss, ii, jj
                       vPos = SwView.Position
                       Ss = SwDim.ReferencePoints
                       For jj = 0 To 2
                                Set MathPt = Ss(jj)
                                Set MathPt = MathPt.MultiplyTransform(SwView.ModelToViewTransform)
                                With MathPt
                                    Pt(jj, 0) = .ArrayData(0) * oScale
                                    Pt(jj, 1) = .ArrayData(1) * oScale
                                End With
                       Next jj
                       RetuDimArr = Pt
              End Function
              Private Sub del()
                  Dim SwAnn As Annotation
                  Dim oScale, Xx, Yy
                  Dim SwSheet As Sheet
                  Dim SwView As View
                  Dim Anns, Arr
                  Dim ii, jj ', Xx, Yy
                  Dim Ss, Ss1
                  Dim SwMathUtil As MathUtility
                  Dim MathPt As MathPoint
                      Set SwMathUtil = SwApp.GetMathUtility
                      Set SwSheet = SwDraw.GetCurrentSheet
                      Set SwView = SwDraw.GetFirstView
                      DelSkPt SwModel, SwView.GetSketch
                      Set SwView = SwView.GetNextView
                      Anns = SwView.GetAnnotations
                      For ii = 0 To UBound(Anns)
                          Set SwAnn = Anns(ii)
                          Debug.Print SwAnn.GetType
                          If SwAnn.GetName = "ArcLen" Then
                          'If SwAnn.GetName = "b1" Then
                                Ss = SwAnn.GetPosition
                                Set SwDispDim = SwAnn.GetSpecificAnnotation
                                Arr = RetuDimArr(SwView, SwDispDim.GetDimension, SwSheet.GetProperties(3))
                                For jj = 0 To UBound(Arr)
                                    Xx = Arr(jj, 0)
                                    Yy = Arr(jj, 1)
                                    Set SkPt = SwModel.CreatePoint2(Xx, Yy, 0)
                                Next jj
                                jj = 2
                                Xx = Arr(jj, 0)
                                Yy = 0.15 'Arr(jj, 1) '- 0.005
                                'SwAnn.SetPosition Xx, Yy, 0
                                SwAnn.Select False
                                Ss1 = SwDim.ReferencePoints
                                Set MathPt = Ss1(2)
                                With MathPt
                                     SwAnn.SetPosition .ArrayData(0), .ArrayData(1) - 0.01, 0
                                End With
                      Next ii
              Function MoveArcLenDim(SwView As View, ArcLenDispDim As DisplayDimension, ShellRDispDim As DisplayDimension)
                  Dim Ss
                  Dim SwAnn As Annotation, SwDim As Dimension
                  Dim SwAnn1 As Annotation, SwDim1 As Dimension
                     With ShellRDispDim
                         Set SwAnn1 = .GetAnnotation
                         Set SwDim1 = .GetDimension
                     End With
                     R = SwDim1.Value * 3 / 4000
                     With ArcLenDispDim
                         Set SwAnn = .GetAnnotation
                         Set SwDim = .GetDimension
                     End With
                     Set MathPt = SwDim.ReferencePoints(2)
                     With MathPt
                          SwAnn.SetPosition .ArrayData(0), .ArrayData(1) - R * SwView.ScaleDecimal, 0
                     End With
              End Function
              Sub del()
                 Dim SwView As View
                 Dim ArcLenDispDim As DisplayDimension, ShellRDispDim As DisplayDimension
                 Dim Anns, SwAnn As Annotation
                         'Debug.Print SwAnn.GetName, SwAnn.GetType
                         If SwAnn.GetType = 4 Then
                            Select Case SwAnn.GetName
                              Case "ArcLen"
                                  Set ArcLenDispDim = SwAnn.GetSpecificAnnotation
                              Case "ShellR"
                                  Set ShellRDispDim = SwAnn.GetSpecificAnnotation
                             End Select
                     Next ii
                     MoveArcLenDim SwView, ArcLenDispDim, ShellRDispDim
                     Stop
