I am trying to do a cut sweep along a path which encircles a concave surface:
The desired outcome is to have the vertical surfaces to remain vertical after the cut. However, this is the outcome. Note that the sweep remains normal to the sweep path. I would like the cut to stay vertical for the entire 360 deg. Is this possible?
Hi Rob,
Use the "align to Vector" option in Sweep picking the "Axis1" - this should work for you.
Mark
