15 Replies Latest reply on Jan 3, 2017 11:39 AM by Deepak Gupta
    How do you get the name of a sketch?
    Frank Sandoval
      I need to write a macro that will get the name of the current sketch and append it to some text which will then be used as a value for a custom property. I've seen one posting on this and tried it but it doesn't work. Can anyone help?
        • Re: How do you get the name of a sketch?
          Solid Air
          Since API calls can change from version to version, what version of SolidWorks are you using?
          Edit:  From SW2017
          Dim swDoc As SldWorks.ModelDoc2
          Dim swSketchMgr As SldWorks.SketchManager
          Dim swActiveSketch As SldWorks.Sketch
              Set swDoc = swApp.ActiveDoc
              Set swSketchMgr = swDoc.SketchManager
              Set swActiveSketch = swSketchMgr.ActiveSketch
              MsgBox swActiveSketch.Name
            Solid Air
            I like this code better (mainly because Feature.Name is documented whereas swSketch.Name is not {as least I could not find it}):
            Dim swFeat As SldWorks.Feature
                Set swActiveSketch = swDoc.GetActiveSketch2
                Set swFeat = swActiveSketch
                MsgBox swFeat.Name
                Frank Sandoval
                Thanks for the response. I'm running SW2016. I've tried both versions posted and while they both work in a message box, they don't work within the program I've written. What I've done is made a custom property called OD1 and am trying to use a text box to enter the dimension name (D!,D2, etc)and appending the @ symbol with the dimension name that's entered into the text box  The error I keep getting is "Object variable or with block not set", happening at the line in bold text. Code as follows:
                Private Sub btnok_Click()
                Dim swSketchMgr As SldWorks.SKETCH
                Dim swfeat As SldWorks.feature
                    Set swfeat = swActiveSketch
                Set swModel = swApp.ActiveDoc
                Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
                Set Part = swApp.ActiveDoc
                swCustPropMgr.Set "SERIES", txtseries.Text
                swCustPropMgr.Set "POINT", txtpoint.Text
                swCustPropMgr.Set "DUCTDIA", txtductdia.Text
                swCustPropMgr.Set "DUCTBC", txtductbc.Text
                swCustPropMgr.Set "OD1", txtod1.Text + "@" + swfeat.Name
                Set swApp = Nothing
                Unload Me
                End
                Thanks in advance.
