GetType of suppressed virtual component in assembly?
Question asked by Norbert Gal on Dec 27, 2016
Latest reply on Jan 2, 2017 by Norbert Gal
I have to check some "properties" on all components in an opened assembly (loop through all sub-assembly level).
I created a loop for it, and first of all I have to check the name and if current component is assembly or not?
This seem easy at first sight but I stucked, because if the "inspected" component is virtual and suppressed, I have no idea how to get these informations.
This is a shoerened code with "looper" function:
Option Explicit
Public swApp As SldWorks.SldWorks
Public swModel As ModelDoc2
Sub Main()
Set swModel = swApp.ActiveDoc
LevelLoop swModel     'first call of "looper" with currently opened assembly
Function LevelLoop(swModelBase As ModelDoc2)
    Dim vComps As Variant
    Dim swModel As ModelDoc2
    Dim i As Integer
    Dim name As String
    Dim compType as String
    If swModelBase.GetType = swDocASSEMBLY Then
        Set swAssy = swModelBase
        vComps = swAssy.GetComponents(True)
        If Not IsEmpty(vComps) Then
            For i = 0 To UBound(vComps)     'loop through all of current asm's components
                Set swComp = vComps(i)
                Set swModel = swComp.GetModelDoc2
                'get component name and type..
                If swComp.GetSuppression <> 0 Then
'if component is RESOLVED or VIRTUAL, "swComp.Name" and "swModel.GetType" works
                    name = swComp.Name
                    If swModel.GetType = swDocASSEMBLY Then compType = "ASM" Else compType = ""
                Else
'if component is SUPPRESSED, "swComp.Name" and "swModel.GetType" doesn't works,
'therefore that was my idea to decide component asm or not, but VIRTUAL components has no path :/
                    name = swComp.GetPathName
                    If UCase(Right(swComp.GetPathName, 6)) = "SLDASM" Then compType = "ASM" Else compType = ""
                If compType = "ASM" Then
                        DoSomething
                        LevelLoop swModel     'the looper function "goes inside" of the current assembly
            Next i
End Function
Anybody has any idea?
Thank you
